driver side rear brake sticking, 93 ranger
ranger 93
15+ Year Member
North Carolina
Hi
93 ranger splash 2 wd, 2.3 , 5spd
I just had my rear brake line replaced from the prop. valve back because of a leak in the line. The problem is now my drivers side rear brake is dragging to the point where after 5 or so miles of driving the drum smokes and is really hot, other side is fine. I dont use the ebrake and havnt in a long time, but when the line was replaced, they used the ebrake, this started happening on the way home. I adjusted the brake shoes down as far as I could and that helped alot, but today I had the exhaust replaced and they put the ebrake on and while driving home it heated up again ( yes the e brake was released before driving, lol) I need suggestions on what could be causing this? Could the ebrake line be sticking on that side? Is it possible to disconnect that side and still drive it? Also, does anyone know how to tell what size the brakes are ( 9 or 10 ") ?
Thanks for any help or advice,
Mike
well if you havent used the e break in years, and they used it during the line replacment, id say the ebreak is siezed
is it ever haha...damn things...try reafing on the cable, wacking it with a hammer see if it breaks free
Can I just disconnect that side? I am not worried about it working right now. I just want to be able to drive it.
Thanks
