Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 10-01-2007, 09:38 AM   #1
mycool88
Year: 1991
Make: Ford
Model: Ranger SuperCab
mycool88 is on a distinguished road
Question Need help on 2nd gear problem...
My mule is a '91 4x4 Ranger Supercab 2.9L w/Mitsubishi FM146 5-speed manual and electronically shifting transfer case. Last week I was going to work and attempted to shift into 2nd gear, and it wouldn't stay...next time I tried it grinded, but would stay IF I held the stick tightly to the bottom of shift range. BUT, if I normally go into 2nd, it won't hold and I skip it altogether...I also notice that the clutch master cylinder reservoir is a little low. I only bled once when tranny was installed, but worked fine, then. Tranny is about 1 1/2 years old and was remanufactured by reputable local rebuild center.
Any help or advice would be greatly appreciated and welcomed!!! Thanks in advance.
mycool88 is offline   Reply With Quote
Old 10-01-2007, 09:54 AM   #2
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
Sounds like the "splines" on the 2nd gear are rounded off. This is a consequence of grinding into gear, so it's not too likely to be a primary problem (it's the result of something else, possibly a clutch release problem).
It's also possible that the thrust clearance is getting a bit wide, but I'd expect the problem to show up in some other gear first, especially 4th.
There is no fix aside from replacing 2nd gear and/or the 1/2 synchronizer slip-ring. I suppose it's possible that ring was installed backwards, but the problem would have shown up right away after installation then.
The most cost effective route is to replace the transmission with a junkyard M5OD. I wouldn't suggest paying to rebuild an FM146. It's not a good design.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 10-01-2007, 11:34 AM   #3
mycool88
Year: 1991
Make: Ford
Default reply...
thanks MAKG...is this a direct bolt-up??? Will start search at JY...
Old 10-01-2007, 12:06 PM   #4
Ranger44
Ranger44's Avatar
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
Look for one out of a 4.0. The 4.0 and 2.9 have the same bolt pattern. Also switch in a 4.0 clutch. It is also a bolt on. There is a right up in the tech section. If you have a 4x4 get a 4x4 tranny. Other than that it should be good.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Old 10-01-2007, 12:25 PM   #5
MAKG
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Default
While 4.0L M5ODs are a LOT easier to find (almost any Exploder with a stick, for instance), the 2.9L ones have wider gearing.
You need the stick as well. Sticks seldom interchange between transmission models. Even closely related ones.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
