| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here. |
Thread Tools | Display Modes |
#1 |
Junior Member
I searched tech but didn't find anything. In Canada we have daytime running lights. On a customer's 99 Ranger the DRL stopped working. Can anyone direct me to the control module location or help withsome troubleshooting. Thanks in advance.
Tweet
#6 |
Year: 2008
Make: Mazda
Model: B4000 SE Cab Plus 4 4x4
Engine: 4.0
Class: 4x4
Rep Power: 0 ![]() iTrader: (0)
The wiring schematics for the DRL is in the US factory manual. This is because DRL is an option on US Rangers (fleet vehicles). up until 2005, they were a module behind the bumper, left side. It had cooling fins on it. If I recall correctly, it contains a relay and resistor to reduce the voltage output. Pre-2005 vehicles have a jumper wire to short the connection and allow the lights to work without the module...that's what most people have...just a plug with a loop wire on it. Every Ranger since 1993 has been pre-wired for the DRL...if you take out that plug and put in a module, you have DRL.
The module is a single unit and replacing it solves most DRL problems unless you've got a wiring or connection issues somewhere down the line. Post-2005, I believe it's controlled by hooking the truck up to a Ford computer and navigating through the lighting menu where you can turn it on or off. It's in there along with the seat belt chime disable and a bunch of other stuff. Requires a Ford computer, but it should be in there. I've never seen it, just heard that.
__________________
2008 Mazda B4000 SE Cab Plus 4 4x4: Think "Ranger Sport" 4.0 liter 4x4 automatic with a Mazda badge, center console & buckets, carpeted floors, and jump seats. You'll be very close to what I have. Last edited by bryan240sx; 11-18-2008 at 11:50 AM. |
Tweet
#7 |
Junior Member
Year: 2010
Make: Mazda
Model: B4000 SE
Engine: 4.0
Class: 4x4
Rep Power: 12 ![]() iTrader: (0)
Check the connection on the module. Mine had lots of corrosion and the 12+ terminal was all rusted... had to change the DRL module.
Tweet
#8 |
Hey, did you have any luck with this, my DRL have been coming on when the truck is not running and killing my batt. I think I located the module, little white box located immediatley in front of the drivers side wheel well, but its not accessable from the top and is pretty tight from the bottom, does this sound right.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
