http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
Besides, I've seen first hand how restrictive Frams are. When cruising with a cold engine, my car runs at almost 80 psi (remember, it's got 24 bucket style lifters to feed so GM didn't skimp on the pump). When I used to use Fram and Penzoil (because that is what I saw my grandfather use) my oil pressure gauge went insane! It was constantly pegged all the time and hardly came down under 80. I got together with one of the guys on the 60v6 board to let him do a chip for my car. Later we went to do cam carrier gaskets because mine had started leaking, and since I had bought a head gasket set to get all of them in there, we decided to pull the heads and port and polish them. When we put it back together he informed me on how restrictive Frams were, so I tried his suggestion of a Purolator and Mobil oil. Well what do you know, after I swapped out the Fram, my gauge worked just fine (and here I thought it was the sensor going bonkers the whole time). Reason being, the sensor is in between the oil pump and the filter. Since Frams are so restrictive, it was building tons of pressure in between the filter and pump and my gauge was recording this.
