installing fog lights behind grille?
bovaddict
15+ Year Member
wayzata mn
Ive seen its on a lot of 01+ rangers and i was wondering which lights i need to fit back there and the process of going about it.. also i have what i think is a oil/tranas cooler back there too.. does this cause a problem?
thanks!!!
Hooking lights up behind the grill is not to hard. If you get a thinner light you should have no problems. It is easier with the stock grill i have noticed. I have a billet grill and had to mount my fog lights on the bumper itself. The only problem is there is a bunch of plastic parts to drill into to mount. I have not looked at it too much but that seems to be the only place to mount them is on the plastic. Let me know if this helps and how it turns out.
hella 500's work? the kc daylighters seemed too thick. and what plastic are you talking about? all i could see to use for mounting would be this like metal support back there, drill into it and mount em that way.. would the back spacing be enough? and would the light clear the spot before the grille?
thanks!!
koopersdaddy- also pics of your truck? id like to see your set up since we got te same truck but yours is white. thanks man!
