| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
I have a 8n tractor with the original 6V positive ground electrical system. The problem is it won't crank over unless it's jump started. The battery, acording to my tester shows it has 8V. If I Put the battery charger on it set at 6V it'll start but if I am in a hurry i put it at 12V.
This battery is only about a yr. old. Is there any way it could be anything but the battery? Solenoid maybe? Any help is appreciated.
__________________
My Website |
Tweet
#2 |
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Used For: Literally everything.
Rep Power: 18 ![]() ![]() ![]() ![]() iTrader: (1)
well, 12v into a 6v system (at least from what I've been told) is kinda bad for the electrical system, too much of a difference or something. It's the AMPs that are what you're after.
It does sound like a bad battery from the symptoms, there is likely a bad ground somewhere that is slowly draining the battery, or the Generator has stopped putting enough current out to charge the battery (but enough to run the engine, had a Cavalier alternator with that issue) Most solenoids I've seen when they go bad have just stopped working all together. I'd check to see how much current the generator is producing and examine all the wires for wear as a start for the diagnosis.
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein Never give up: http://www.youtube.com/watch?v=Y6hz_s2XIAU 1984 Ranger - std cab, long bed: The Deathtrap 302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear 1997 Ranger - std cab, short bed: Red Ranger 2.3L; M50D R1; 2wd; 4.56 gears; Explorer 8.8; ARB locker; 235/75R15 AT's (soon to undergo 4x4 conversion |
Tweet
#4 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Thanks, i'll check it out tonight.
__________________
My Website |
Tweet
#5 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
The generator is putting out 7.4volts. I think i'll put a 8volt battery in it this weekend and see how that works for awhile. I have a friend who is a rep for interstate he can get me one cheap.
__________________
My Website |
Tweet
#6 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Without lights it shouldn't require much juice at all to run it. You should get more than a couple starts before the battery is flat, if it goes down fast you have problems elsewhere.
I would look into a 12v conversion, 8v is a bandaid. 6v requires everything to be almost perfect to work right and is a pain for a working tractor.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#7 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
Rep Power: 10 ![]() iTrader: (28)
Go throught the system and clean all the connections.
Could the battery have frozen perhaps? It would take exposure to extremely cold tempuratures to kill it, not just below 32F or 0C. Since you can still start it, its not the solenoid. I would lean towards a bad connection. I had a bad ground on my starter. It would start first time when cold but after that it would not start. I would have to wait a couple hours to try to start it again or I would have to smack the starter with a hammer to make it get a better connection again.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall. http://www.therangerstation.com/foru...ad.php?t=21890 1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now... 1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only. |
Tweet
#8 |
There is nothing wrong with a good working 6v positive ground system. I have a 6v system working on an old standby generator... Still works just fine... You just have to do a little more maintenance from time to time (keep the connections clean)
Clean the crap out of all the connections... If it has an open mechanical start switch (I can't remember, it's been a long time since I worked on an 8n), clean it and hit the contacts with steel wool. Then test the battery, if that checks ok, check the starter. Don't do the 8v system, You'll just kill everything else in the electrical system sooner. Make certain that all of your cables and connections are good before anything else!!
__________________
98 Ranger XLT 2.5 lima RIP 04 Ranger XL 3.0 Vulcan RIP Currently 04 XLT Supercab 4x4 4.0 5 spd 4.10 axles (Hell YEAH!) Paul Johnson KC2TOO |
Tweet
#9 |
Year: 1996
1991
Make: Ford
Jeep
Model: Ranger Supercab
Cherokee
Engine: 3.0l
Class: 4x4
Used For: My son's daily driver now.
Rep Power: 12 ![]() iTrader: (0)
You said the battery is one year old.
Do you mean, you bought it one year ago? If it sat on the shelf for four years because no one needed a 6 volt, then the battery is no good. Get your interstate guy to get you a 6 volt battery and try it before you burn up the starter using an 8 volt, or burn up the 6 volt generator trying to recharge an 8 volt battery. |
Tweet
#10 | |
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Quote:
It's looking more towards a shady connection like the others mentioned.
__________________
Tweet
#12 |
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
Rep Power: 16 ![]() ![]() ![]() iTrader: (0)
we had a '64 ford 4000 series that was always a pain to start. it was originally a 6V system. converted it to 12V and added a alternator and it started much better. seemed like it was taking so much amperage to run the starter that there was very little spark from the coil. is it a front distrubutor? those are a pain to deal with. we also have a old 8N with a bachoe/loader as well as a '46 2N that was bought new the year dad was born. the 8N hasnt been ran in years, we robbed parts off it (carb, distributor) to get the 2N running when we overhauled the motor when i was still in high school. (over 20 years ago) id like to get the 8N going again someday. the 2N has no starting issues. will run forever on a tank of fuel too. both our "N" series tractor have the sherman overdrive. the 2N will do 20 mph in 3-overdrive.
__________________
at the corner of "walk" & "dont walk" cardomain link:--> http://www.cardomain.com/ride/3216869 1993 ranger s/c 4.0 hurst-equipped 5-spd,3.73s ,4x4, milemarker hubs, black grille guard/tube steps,summit rear diff cover with bearing load supports. 117K & still going strong. http://www.myspace.com/small_dog_trucking |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
