Borg Warner 4405 Transfer Case
thewrens1
10+ Year Member
1 - Does the 4405 transfer case have have neutral position?
2 - With the transfer case is 2HI - could the vehicle be towed with the front wheels on the ground with no damage to the transfer case and/or transmission?
Thanks for any help.
Thewrens1
Allegedly there is some bizarre combination of control manipulations that along with sacrificing a goat (though some say a Virgin works better) at midnight on all Hallows eve
(You are in luck as that's only one month away) that will "Trick" the 44-05 into neutral.
other than that? remove the driveshaft before towing.
Or you could just look for towing instructions in the owners manual...
AD
