No more leaves please....
jcmtbfreak
15+ Year Member
I know this has been talked about, but I was wondering if anyone had any pics. Where is the spot to put mesh wire so leaves don't end up down in the passenger floorboard? Hmmmm, doesn't snow come in there as well? How do I stop that?
it comes in the cowl vents...the openings on the outside of the truck right at the base of the windshield.
snow should melt and drain through the holes in the bottom of the cowl. if it doesnt, the drain holes are probably plugged...i would get them cleaned out before you start to get a lot of water leaking into the cab.
