89 Ranger manual t case and auto hubs
dieselranger
10+ Year Member
Quakertown, PA
Can I use a manual t case with auto hubs on my dana 28? If not can i swap to manual hubs from an earlier truck?
If you decide to swap to manual hubs you need the spindle nuts and lock washer too or the hubs won't fit.
Matt
DANGER! Yes, you can do this swap BUT. . . you must stop your truck completely before engaging the 4x4 - you can't shift "on-the-fly" with auto hubs and a manual transfer case - I'm not sure the reason, but that was the problem I had. I found out the hard way - the hubs won't engage completely if the truck is rolling. That was my experience anyway. Good luck!
