Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-21-2008, 01:57 PM   #1
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
campermama is on a distinguished road
Default RIght side Overhead Cam
Is it possible to remove this without removing the engine? It is a SOHC, 4.0L, V6, 2001 FOrd Ranger 4x4
Thanks.
campermama is offline   Reply With Quote
Old 09-21-2008, 03:39 PM   #2
Ranger5.0
Ranger5.0's Avatar
Year: 1993
Make: Ford
Model: Ranger XLT
Class: 4X4
Used For: DD, Wheeling,
Ranger5.0 is an unknown quantity at this point
Default
why are you wanting to pull one cam? I imagin you can tho
__________________
" MAKG-If you're making a snorkel, you don't need anywhere near 3 inches. You're not going to be running drag races in a river"
93' EXT,on the second 302H.O 3" single exaust,Deltaflow 40/AOD/13-56/F-150 coils, Explorer/ranger leafs.
Ranger5.0 is offline   Reply With Quote
Old 09-21-2008, 03:41 PM   #3
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
Default
Quote:
Because we need to pull the head and repair the plug threads that got cross threaded. The book says pull the engine but we are wondering if that is really necessary?
Old 09-22-2008, 05:31 PM   #4
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
Oh sure you can pull it apart without taking the engine out of the chassis.
The problem is you cannot put it back together with the engine in the chassis.
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 09-22-2008, 08:01 PM   #5
MAKG
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
AD
Let me guess.
You can't get the timing chains back on and correctly synchronized?
It's A LOT easier to work on an engine on a stand than inside a big steel box with lots of stuff in the way.
There are some tricks to repairing a spark plug without pulling the head, but see the previous sentence. If you crossthreaded a spark plug, you're going to have that much more trouble with an insert. Things get REAL fun when you break a tap in there.
Any chance this is #3 and you have air conditioning? If so, you'll NEVER fix this thing with both the engine and the evaporator installed.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 09-23-2008, 09:35 AM   #6
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
Default
Believe it or not #3 is fine! It is #1 & 2. We have almost everything off the engine now and are just about ready to pull it if we really have to. My friend a mechanic is sending me instructions saying we don't need to pull it, but we will see........
Old 09-24-2008, 11:07 PM   #7
woodyedmiston
woodyedmiston's Avatar
Year: 99
Make: Ford
Model: Ranger
Engine: 4.0
Class: 2WD
Used For: Work, Transportation to all-u-can eat buffets.
woodyedmiston is on a distinguished road
Default Listen!
You should listen to the folks on this site and stick to what you have experience and training to do . . . take the truck to your friend the mechanic, or to a mechanic who is not your friend.
You just learned to floss - this is a root canal
woodyedmiston is offline   Reply With Quote
Old 09-25-2008, 01:15 PM   #8
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
Default
Old 09-25-2008, 01:15 PM   #9
almostclueless
almostclueless's Avatar
Year: 98
Make: ford
Model: ranger
almostclueless is on a distinguished road
Default
I'm glad I learned to always start a spark plug by hand, not wrench, on a motorcycle instead of a car when I was a kid.....
__________________
1. MORE COWBELL!
2. Chuck Norris can win Connect Four in three moves.
3. What the H___ is an aluminum falcon!?!
4. sham....WOWWWW
almostclueless is offline   Reply With Quote
Old 09-25-2008, 02:40 PM   #10
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
Default
Quote:
We did start them by hand, we didn't just fall off the turnip truck, not sure what happened
Old 09-25-2008, 05:57 PM   #11
MAKG
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Default
Quote:
They can't have been started by hand and then become crossthreaded, unless you put the wrong spark plugs in and they have a different thread (kinda hard to imagine -- I've never seen that).
It's not just spark plugs that should be started by hand. Anything with threads.
__________________
Old 09-26-2008, 11:23 AM   #12
campermama
Junior Member
Year: 2001
Make: Ford
Model: Ranger
Default
We did all 6 by hand, the other 4 are fine, so not sure how, or what, or why, of what happened to these 2.
Still trying to figure out if we really gotta pull the engine or not though, that is what this thread is about.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
