Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-20-2008, 07:00 PM   #1
Payitforward
Year: 1983
Make: Ford
Model: Ranger
Payitforward is on a distinguished road
Default What type of trans fluid?
We are getting the 83 C-3 automatic rebuilt, (again) what is the correct type and amount of fluid to refill?
I don't want to run it low or with incorrect stuff. One book I saw said Mercur 2, but I've read various thread opinions on that topic?
Also I want to purge all the old fluid from the lines, converter and radiator/cooler.
Any suggestons on that (force it out with an Air hose?).
And finally is it preferable to fill up the converter prior to putting it in the trans and trans in the truck?
What I've read:
stock Converter holds just over 4 quarts
stock c3 holds 8 quarts
Does this account for the lines and radiator/cooler?
83 Ranger 2.8V6 2wd, thanks in advance.
Just helping out a young friend.
Payitforward is offline   Reply With Quote
Old 09-20-2008, 07:08 PM   #2
Mutant Pony
Mutant Pony's Avatar
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Used For: Mud racing/trails
Mutant Pony will become famous soon enough
Default
I would suggest a rebuilt converter as well. If not it should have a drain plug. All the older Fords did.
I would run dextron III or better fluid.
The only "wrong" fluid is the cheap, dollar store, ATF. It will work just fine with type F as well.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 09-20-2008, 07:45 PM   #3
Payitforward
Year: 1983
Make: Ford
Model: Ranger
Default
It does have a drain plug in the converter and I got 4 qts out of it.
Looked really nice and shiney blue so I'm guessing it isn't the original converter and has been replaced. Thanks for the info on Dextron III.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
