Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-17-2008, 08:20 PM   #1
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Used For: Giving me pride.
koda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to behold
Default Transmission randomly going into neutral?
Okay, so I've been having a problem lately. Every once in a while I'll go to leave with my truck and all the sudden it will just stop moving, like its in neutral. Then eventually pop into gear once I sit there or rev it a lot. Any ideas on what could be causing this? If it helps, I'll include the two most recent situations that this has happened.
Yesterday, I drove to school and everything was fine. At the end of the day the Ranger started up normal and I drove it about 20-30 feet where I had to stop to let a school bus by. When I went to go after it went past, all I got was "vroom." Knowing that this happens sometimes, I sat there for a bit and waited, then tried again, same thing. Eventually I heard a loud "clunk" and the truck lurched forward a bit, that's how I knew it finally went into gear. I had it in drive the entire time. No problems that day after that. Drove to the park, gas station, to my girlfriends, and then back home.
Today, I went to leave to go to town, backed up out of my spot and since my brother was blocking the other driveway with his Nissan (POS) I popped it into drive and went about 20 feet around a curved driveway leading to the other exit. I stopped and waited for a couple cars to drive by, then proceeded to ATTEMPT to leave the driveway, all that happened was once again the engine revved and the truck didn't act like it was in gear, but this time since I was on a slope I DID go forwards, into the middle of the road, I sat there freaking out trying to get it to go in reverse or in drive with no results at all, a bunch of cars went by thankfully on the other side of the road from the one I was partially in and then a few started coming on my side. Thankfully they went around me. After they went by, it finally popped into drive and I took off. No problems today after that. Drove to the post office and to the store, and back home only shut the truck off once.
Any ideas? My truck is a 1993 Ranger Supercab 2wd with an Auto tranny (A4LD?) and a 3.0.
__________________
1993 Ford Ranger XL Supercab 3.0 V6. Custom interior. Edge Conversion (WIP). 03 Explorer seats. 6" lift (WIP). Sitting on 35x12.5R15 Mastercraft Courser MT's.
1997 Jeep Cherokee Sport. 4x4/4.0/auto. Daily Driver & parts snagger.
Ranger Build Thread.
Jeep XJ Build Thread.
koda6966 is offline   Reply With Quote
Old 09-17-2008, 08:59 PM   #2
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
Bump. This really worries me.
__________________
Old 09-17-2008, 09:20 PM   #3
Bruce
Bruce's Avatar
Year: 2002
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0 SOHC
Class: 4x4 4:10 gears
Used For: Daily Driver
Bruce is on a distinguished road
Default
Have you check the fluid level??if fluid level is low it will cause this problem also.
__________________
2002 Ranger Supercab 4x4 4 door 4.0 with 4:10 gears.
Bruce is offline   Reply With Quote
Old 09-17-2008, 09:43 PM   #4
igiveup
igiveup is on a distinguished road
Default
Hello
Quote:
Also when was the last time you changed the transmission filter. Have you ever adjusted your bands? A4ld have there problems.
I like mine now since I have a better setup. Its a 94 Areostar with the VB from the 85 and also has a shift correction kit installed.
igiveup
__________________
2011 FX4 Ranger http://therangerstation.com/forums/s...98#post1067998
85 Honda trike 250 SX
2006 F150 4X4 quad door (tow rig)
igiveup is offline   Reply With Quote
Old 09-17-2008, 09:57 PM   #5
Bent Bolt
Bent Bolt's Avatar
Year: 1987
Make: Ford
Model: Ranger STX
Engine: Supercharged 4.0 SOHC
Class: 4x4 Offroad
Used For: Breaking parts , sitting in the back lot
Bent Bolt is on a distinguished road
Default
Quote:
Originally Posted by igiveup View Post
Hello
igiveup
Neither of those will cause the problem in question.
koda6966, check the ATF level. Is reverse OK ?? Next time it happens, pull the shifter down from O/D to D. If no change , pull it to MAN1. Post the results. That'll give a clearer picture of what is gong on.
__________________
87 Ranger , a bunch of stuff including a supercharged 4.0l SOHC and 35 x 14.5 x 15 Pitbull Maddog's. Woof !
Now with C5/C4 hybrid !
Bent Bolt is offline   Reply With Quote
Old 09-17-2008, 10:12 PM   #6
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
I'm always in drive.. hate having to move the shifter over to OD. Reverse wasn't okay, it was like I was in neutral, but I was in drive. And yes, the fluid level is normal.
__________________
Old 09-17-2008, 11:05 PM   #7
Bruce
Bruce's Avatar
Year: 2002
Make: Ford
Engine: 4.0 SOHC
Default
May possibly be the oneway sprag in the converter going out, which would mean converter needs replacing..since it seems to happen in any given gear.
__________________
Old 09-18-2008, 07:16 PM   #8
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
So if that is whats wrong with it.. how bad is it/costly to fix?
__________________
Old 09-18-2008, 09:16 PM   #9
Bruce
Bruce's Avatar
Year: 2002
Make: Ford
Engine: 4.0 SOHC
Default
Cost to fix it would depend on where ya live...which i see you in NY and i dont know what labor rate is or what parts would cost there..If you gona do it yourself i would go to a parts house and see what a converter cost( you have to remember we are only taking a shot in the dark as to what is wrong) and if you gona have it done take it to A tranny shop for a quote or to see what they think it maybe and they can give a estimated cost of repair. you cost of repair
__________________
Old 09-18-2008, 10:31 PM   #10
Bent Bolt
Bent Bolt's Avatar
Year: 1987
Make: Ford
Model: Ranger STX
Class: 4x4 Offroad
Default
No. A bad sprag in the converter won't cause a intermittent neutral condition. They either work or don't.
Hate to tell you Koda but I think you are having a pump failure. You are losing line pressure. There is a small chance that the o-ring on the filter may have failed but unless you recently replaced the filter, the chances are slim.
__________________
Old 10-04-2008, 07:16 PM   #11
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
Pump to/from what and where would it be located?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
