| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Non RBV Tech For discussing tech other than Ranger related. |
Thread Tools | Display Modes |
#1 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Used For: Giving me pride.
Rep Power: 33 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (4)
Well, as some of you know I have an Escort that I use as a storage unit. Basically it sits in my yard full of boxes. I got to thinking today about how nice it would be if it actually ran, since it got 40 miles to the gallon back in it's prime. What some of you don't know.. is that it was trashed shortly after 9/11. 7 years of sitting in my yard can do a lot to a vehicle. I checked under it today, and it SEEMS like it doesn't have as much rust as I once thought. It just started rusting a while ago after someone removed the battery. It had an "electronic rust inhibitor" on it. So rust isn't an issue with it. What is an issue, is the possibility of a bent frame, and the fact that it wont start. There doesn't appear to be anything wrong with the engine, and as far as I know the transmission works fine. Right now, what I think the reason is for why it doesn't work is how it's had a full tank of gas.. for 7 years.. obviously we all know that gas goes bad in a tank after a while. So here's what I'm wondering, should I just drain the tank, and put a tad bit of fresh gas in it to see if it runs, or will I need to replace fuel lines, tank, filter, etc? I would be trying to spend as little money as possible. Since I still don't know if the frames bent and have no way to tell unless I can get it to run/move.
__________________
1993 Ford Ranger XL Supercab 3.0 V6. Custom interior. Edge Conversion (WIP). 03 Explorer seats. 6" lift (WIP). Sitting on 35x12.5R15 Mastercraft Courser MT's. 1997 Jeep Cherokee Sport. 4x4/4.0/auto. Daily Driver & parts snagger. Ranger Build Thread. Jeep XJ Build Thread. |
Tweet
#2 |
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4x4
Used For: Daily driver, off roading
Rep Power: 11 ![]() iTrader: (1)
The Injectors will probably have gunk in them, along with everything else that had gas in it for that long. I guess you can try, it might get enough fuel through the system to run. If it does run, it won't be pretty. Run some seafoam in the gas if it does start to clean the gunk out a little bit, but it wont do much if you dont have fuel flow. IMO save up and get a $500 car that is actually running at the moment if you dont want to spend alot of money. Which it might take to get the escort running again.
Deffinatly will need a new fuel filter BTW.
__________________
6" lift. 33" tires ![]() Last edited by motohead771; 09-13-2008 at 10:41 AM. Reason: fuel filter |
Tweet
#3 | |
Year: 1996
1991
Make: Ford
Jeep
Model: Ranger Supercab
Cherokee
Engine: 3.0l
Class: 4x4
Used For: My son's daily driver now.
Rep Power: 12 ![]() iTrader: (0)
Quote:
Bad gas won't mix with the new gas, it will still clog the pumps and injectors. But, you can get her done.. My Mustang sat for 15 years, had to open up the access hole for the fuel float to get all the rust out. Yours has an in-tank fuel pump, right? |
Tweet
#4 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
What's the scrap price these days for about 2000lbs worth of car?
__________________
Tweet
#6 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Haha, just checking my options.
__________________
Tweet
#7 |
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Pshaw. 7 years?
I'd drain out the whole tank of gas from the fuel filter line, bumping the key to run to speed it along (fresh battery). Clean and gap the plugs. New gas, new fuel filter, new battery, change the oil IF it starts. Those fuel hoses should be fine. Injectors can be cleaned. I bet it'll start. |
Tweet
#8 |
Super Moderator
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
If you can find 2,000# of metal in it you could get $220. I sold a 600# load of bus seat frame for $66.00 a couple of weeks ago. Probably you could find $150 worth in it. They give you less for asembled engines and drivetrain parts because they have to pay minimum wage to get them disassembled and sorted. You also get less for a body because of the glass, plastic and upholstry.
Of course then you would have to give up the attractive yard ornament. So, why was it parked in the first place? And parked with a full tank of gas?
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights. '87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit '96 VW Passat Tdi '00 Ford E350 15-pax Powerstroke '09 Suzuki TU250X '04 Moto Guzzi Breva http://willwills.com/ |
Tweet
#9 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
It is a wreck, even after you get it going you will still need to fix the bodywork to get it driveable right?
I would find a similar car with a engine/transmission problem cheap, do a switcheroo and junk the leftovers.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#10 | |
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Quote:
Anyway, cleaned her out today and I'm going to be stripping it of anything I can test stuff on before doing it to my Ranger. How much do you think I should get for it at a scrap yard?
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
