| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Steering This forum sponsored by: B/A Metal Fab |
Thread Tools | Display Modes |
#1 |
Junior Member
Year: 1990 Ranger 4x4
Engine: 2.9
Class: 4x4 Modified
Rep Power: 12 ![]() iTrader: (0)
Is there a such thing as a high performance power steering pump for a ranger?
My truck does not always want to turn since I put the 35"SX's on it while it is locked in. The steering wheel stops and the belt squeeks a little, but it's as if it don't have enough pressure/power to turn it or something? Any ideas????? (besides belt tension)
__________________
1990 Ranger 4" lift /3" body lift, 35x15.5 SX's, 8.8 w/ Detroit Locker Dana 35 front w/ECTED, 4.56's extended radius arms, EB springs, long Duff shocks, Snorkel, Tabor 9K winch, dual batteries, Electric fan, External roll cage, on-board air, bobbed bed, and some other stuff |
Tweet
#2 |
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Rep Power: 21 ![]() iTrader: (0)
It's always hard to steer a locked front end. You have good traction and do not need the locker. Put in a stronger steering system, and you'll break stuff. SOMEthing has to give. It's supposed to be the dirt/mud/whatever under the tires, but failing that, wouldn't you rather have the belt squeal a bit, as opposed to an axleshaft breaking?
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage. 1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles. 1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2. |
Tweet
#3 |
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Rep Power: 18 ![]() iTrader: (38)
Saginaw:
There was another guy who put a saginaw pump on a 4.0. He's got a small "write-up" on car domain. But here's what I did on my 2.3. I will be swapping this over to my 4.0. http://www.therangerstation.com/foru...pump+installed The only other option is an AGR pump. They are expensive and are basically a souped up stock pump.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark. Giddywomp Offroad & Fab
Tweet
#4 | |
Year: 1973
Make: FORD
Model: F250-HI-BOY
Engine: 390C.I
Class: 4X4
Used For: whatever i want [ like driving over small jap cars that cut me off ]
Quote:
__________________
IF YOU DRIVE A JAP CAR, DON'T LET YOUR ALLIGATOR MOUTH OVERLOAD YOUR HUMMING BIRD ASS OR I WILL DRIVE MY U.S. BUILT FORD RIGHT OVER THE TOP OF IT LIKE A SPEED BUMP.![]() --------------------------------------------------- 1973 F250 4X4 W/390-C6AUTO W/205 DIVORCED TRANSFER.............GEARDRIVE |
Tweet
#5 |
Year: 1995
Make: Ford
Model: Ranger Splash
Engine: 4.0 V6
Class: 4x4 Off-Road
Rep Power: 13 ![]() iTrader: (4)
The steering gear box is actually the same on both a ranger and f-150.
__________________
95 Ranger Splash, 4.0, M5OD-R1, BW1354M, D35, Exploder 8.8 31spl 4.88, No-Slip, SJ Class II 8" Lift, 3" BL, F250 Shock Towers, Bilsteins, 1pc DS, 35" BFG M/T KM2s on 15x10s... 95 Explorer, 01 ST, 03 Explorer 4.6 2V V8, 08 ST Adrenalin 4.6 3V V8 |
Tweet
#6 |
Year: 1991
Make: Ford
Model: Explorer Sport
Engine: 4.0 OHV
Class: 4X4 Extreme
Used For: Wheelin
Rep Power: 14 ![]() iTrader: (0)
Maybe you have a problem with your steering system?
I have no problem turning my 35s on a locked front, and my steering is bone stock.
__________________
2001 Mustang Cobra SVT convertible: 5-speed, 320HP V8, 0-60 in 4.8 2009 Chevy Aveo 5-door LS: 5-speed, DD |
Tweet
#7 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I would start with the little stuff first.
Tighten that belt.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#8 |
Year: 1987
Make: Ford
Model: Ranger STX
Engine: Supercharged 4.0 SOHC
Class: 4x4 Offroad
Used For: Breaking parts , sitting in the back lot
How wide are your wheels and what kind of backspacing ??
__________________
87 Ranger , a bunch of stuff including a supercharged 4.0l SOHC and 35 x 14.5 x 15 Pitbull Maddog's. Woof ! Now with C5/C4 hybrid ! |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
