Newb with?'s
STANG3O2
15+ Year Member
osceola, WI
Well I have some plans for my bronco. But have a lot of questions before I start. My plan is to drop the 3.8l out of my 94' Cougar into the bronco. And as I've been reading up on swap how to's. And have ran into a few things that are still unclear.
First, involves the trans. What trans do I need? Can the a4ld be adapted to the 3.8l? Or can I drop in the motor and the 4R70W out of the cougar into the bronco? Or does this swap need a mandatory c4 or c5?
Second, I plan to add a 3" body lift at the same time of the motor swap. What little things should I expect to have to replace at the same time? Brake lines?
Third, what do I have to do for motor mounts? I see James Duff has motor mounts for a 5.0 swap. Will these also work for the 3.8l?
Did I post this in the wrong thread? Or has no one ever done this swap before?
It isn't worth the effort... it's as much work to put a 3.8L into a RBV as it is a small block V8, and you get less power and reliability.
One from a 3.8L or a small block. You can use the 4R70W if you buy a $500 adapter to use the stock t-case...
Steering shaft extension, trim the floor for the t-case shifter to get into low...
James duff mounts bring the suck. Yes, the 3.8L uses small block mounts.
Thanks, for the reply. Since I already have the donor car I figure that its worth it. Even if it takes a little exta effort.
Well I gues I'll be looking to do this swap sooner than I had thought. I drove the bronco into work today, about 35 miles. And slowly the trans started shifting eraticly and sliping from time to time. Hopefully I can get back home with no issues.
I have been thinking about doing the same swap. only diffrence is the 3.8 I have is outta
a thunderbird sc. I personaly think that you get more bang with this combo vrs. the
small block. a little tweak here and there with the supercharged 3.8 and you can keep up
with the 5.0 and still save weight. any who lmk how this works for you.
