Gear oil for 1988 5 Speed Manual
jonnymotox
10+ Year Member
Frazier Park, Ca
What Type Do I use?
The manual says, ATF?
Is this Right?
and how much do I add it's empty
Which transmission do you have? FM146 or M5OD?
Yes Mercon IV ATF. It should hold around 2.5 quarts, add until it comes out the hole.
Mercon IV ? :icon_confused:
Use "Mercon" fluid (nowadays it has names like "Dex/Merc" or "Domestic Vehicle ATF" on the bottle (stating that it meets the Mercon specification).
Don't put Mercon V in that though, the shift quality may be degraded if you do
Damnit my bad, all these ATFs have got me confused, I can always just remeber not to use use Mercon V, the correct stuff is marked Dex/Merc as you said.
