Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 09-17-2007, 07:09 AM   #1
Bow_Extreme
Junior Member
Year: 1994
Make: FORD
Model: RANGER
Bow_Extreme is on a distinguished road
Default Rear Drive shaft question
I have a 2 piece rear shaft out of a 93 4x4 supercab. I have this posted for sale and I'm converting to a one piece shaft. The question being, I have a buyer interested who has a 89 4X4. Will this shaft fit that year truck? I'm trying to find out if the truck is a supercab. All info is very much appreciated!!
Bow_Extreme is offline   Reply With Quote
Old 09-17-2007, 04:12 PM   #2
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
It would have to be a supercab. Have him measure his driveshaft and you measure yours. That would be the sure fire way for no mix ups. The flanges probably won't interchange but as long as the u-joints are the same width he can put his old flanges on your shaft. Some of the older Rangers had tiny driveshaft u-joints. I can't remember when they increased the width but if he has the small joints there are a few options. 1. hope the companion flanges on his truck are the same as yours. 2. If not he will be going to the junkyard to look for a bigger u-joint shaft for the flanges with his pattern. If that's the case then he should just get a shaft there because most junkyards won't separte the yokes from the shaft.
Matt
Matt
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 09-22-2007, 04:07 PM   #3
RockyMTNCanuck
Year: 1994
Make: Ford
Model: Ranger SuperCab
RockyMTNCanuck is on a distinguished road
Default
Now that someone has brought it up, I have a question about the flanges
if anyone has experience with this:
I have a one-piece driveshaft from an '04 FX4 coming my way, and it has the
3" flange on it instead of the 2.5" I need to mount up to my 1994 T-Case. If
I can pull the yoke from my old two-piece and mount it on the new one-piece
it will save me the hassle of trying to dig up the right bits at the local wrecker. It hasnt shown up yet so I can compare them the old fashioned way...
If anyone knows, share with the group would ya?
Thanks in advance,
Damon
RockyMTNCanuck is offline   Reply With Quote
Old 09-22-2007, 08:21 PM   #4
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Thanks in advance,
Damon
The u-joints are bigger on the one-piece shaft, the yoke will not swap (unless you use a "conversion" u-joint).
The flange on the t-case can be swapped for the bigger one however.
On the original Q here, the '93 S/C shaft should fit a '89 S/C, except the rear axle flange is smaller on the '89, the rear driveshaft flange would need to be swapped (if the original '89 part is available, IIRC it should work on the '93 shaft).
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
