| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
Year: 1993
Make: Ford
Model: Ranger 4.0 Super Cab
Engine: 4.0 V6
Class: 4X4
Rep Power: 0 ![]() iTrader: (0)
I have a 93 ranger 4.0 super cab and I what to install a locker in the rear diff. I open up the diff last night and I think she has a ford 8.8 Trac-Loc. It looks just like the picture on the tec page “Diffs for Dummies”. Question: is the Trac-Loc a Limited Slip diff and will a Powertrax No-slip locker fit in it?
Tweet
#2 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
Is the rearend tag still on the rearend? If it is look at it, the first numbers you see should look like this 3 L 55, 73. If it's a 4.0 it probably does have a 8.8. If you are buying a locker from a company they should be able to tell you if it will work in place of your current locker.
__________________
HE WHO DIES WITH THE MOST TOYS WINS |
Tweet
#3 |
"Outlaw"
Year: 1991
Make: Chevrolet
Model: K-3500
Engine: TBI 350
Class: 4x4 Extreme
Used For: Exploration
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
The No-Slip will not fit into an L/S carrier. You'll need to find an open carrier to use, or find a full-replacement locker.
__________________
Trail Rig (1) - 1991 Chevy Silverado - [Build Thread] (SOLD 12/2/2011) Trail Rig (2) - 2007 Polaris Sportsman 500HO EFI Tow Rig - 2004 Dodge Ram CTD - [Build Thread] Earth Resin Offroad |
Tweet
#4 |
Year: 1993
Make: Ford
Engine: 4.0 V6
Class: 4X4
I defiantly have a ford 8.8 dif. How can I tell if it is an open differential? I thought I had an 8.8" Ford 28-Spline with an open differential. Now I am not so sure. What is an 8.8 Trac-Loc diff? I have a "S" spring in there that I was not expecting. Do I have an open differential? Any help would be great.
Tweet
#5 |
"Outlaw"
Year: 1991
Make: Chevrolet
Model: K-3500
Engine: TBI 350
Class: 4x4 Extreme
If there is an S spring in there, its not an open differential. You have a limited slip (trac-lock) differential.
__________________
Tweet
#6 |
Year: 1993
Make: Ford
Engine: 4.0 V6
Class: 4X4
Thank JohnnyU that helps alot. I think I bought the wrong locker. To be clear the Powertrax no-slip will not fit my diff?
Tweet
#7 | |
Year: 1995
Make: Mazda
Model: B4000
Rep Power: 12 ![]() iTrader: (0)
Quote:
Now with this stated, I recommend that you obtain an Open Carrier to install your lockrite into. I have heard that the relief cuts in the L/S carrier for the clutch packs makes the carrier weaker and more prone to breakage. |
Tweet
#8 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Yes, they do make a No Slip for LS 8.8 carriers.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
#9 |
Year: 1993
Make: Ford
Engine: 4.0 V6
Class: 4X4
The No-Slip that will fit into a L/S Carrier, Part Number 92-0688-2827, is made for 31-spline axle? Are all the L/S in the ford 8.8 comes with 31 spline axle? How can I tell if the L/S diff in my ranger is a 28 or 31 spline axle? Everything I have read it should have been an 8.8" Ford 28-Spline with an open differential.
Tweet
#10 |
It's only money...
Year: 1993
Make: Ford
Model: Ranger
Rep Power: 10 ![]() iTrader: (2)
If it's the original axle from that 93, then it's a 28 spline.
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's Fullwidth D60, Lockright, 5.38's, Dedenbear C's 14BFF, 5.38's, Detroit, Disc Braked 3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts |
Tweet
#11 |
Year: 95
Make: Ford
Model: F250
Engine: 7.3
Class: 4X4
Used For: Work and play
Rep Power: 15 ![]() ![]() ![]() ![]() iTrader: (1)
They make a noslip for a 28 spline trak-lock, I have one.
__________________
95 F250 Xtracab Powerstroke, 5 speed, 4X4, Stock for now |
Tweet
#12 |
Junior Member
Year: 1984
Make: ford
Model: ranger
Yep, Powertrax makes a No-slip locker that will fill an l/s 8.8- I have one in my truck right now...the install was a piece of cake. also, mines a 28 spline axle also. Go to Jeg's or Summit, they both carry them.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
