need help 92 4- runner [brakes]
mkpecor
15+ Year Member
black diamond W.A.
over the weekend i put on a new brake master cylender and calipers on the wifes runner, i went to bleed the brakes and cant get any fluid comeing out of the bleeder,:temper::pissedoff: i get fluid to the front not the back. do i need to pressure bleed this thing? any ideas would help very much. thanks mike
Does it have RABS? If so, that might be your problem and I would just run a brake line right past the RABS module. Thats up to you though.
what the hell is rabs" rear ani brake system?
yep.
Have you tried pulling the rear bleeders and seeing if you get any fluid? Just pull the bleeder and give the pedal a slight little push. You may just have stuck bleeders. It might be worth while to replace them anyways.
