Code 111 and Code 332
Ranger SVO
15+ Year Member
Abilene Texas
The other day (tuesday) the Check Engine Light came on in my truck. Now it only stayed on for a few minutes. It has not come on again.
Today (saturday), I decided to retrive the stored codes. The first code was code 111, which means everything is OK or system Pass
The only other code was code 332 which means that "Insufficient EGR flow detected.
OK, Great, what do I do now? It did not turn on the Check Engine Light because it was bored, there was a problem. What do I need to Check?
well you should probably start with the egr valve if you're worried about it.... but if it runs fine and dosen't come on again, i'd leave it alone.
If I remeber correctly, a light won't appear until the same fault happens twice within a certain peroid/#of driving cycles. It may have been a fault that only happened once.
Maybe check the metal tube that runs for the manifold to the egr valve and see if it is gummed up, dirty, or blocked.
