Go Back   The Ranger Station Forums > Styling & Electrical > Heating & Air Conditioning
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-16-2008, 08:09 PM   #1
LordVngr
Junior Member
LordVngr's Avatar
Year: 1989
Make: Ranger
Model: STX Supercab
Engine: 2.9L
Class: 4x4 Sport Rider
LordVngr is on a distinguished road
Default Dumb AC Question and dealer installed AC
Ok, Soooo How do I take this off
With This
I just Dont Get It.
I Also found out that I have Dealer Installed AC. Check out my hose connections. The condenser hose's use the same type clamp. Is that going to hold up to the pressure of R-134a.
I was pissed when I found out I had Dealer installed AC. I'm trying to rebuild my AC system. Couldnt I just use the compressor bracket from a junkyard and install the factory compressor / condensor / hoses instead of this style and it's mickey mouse setup. Also since it is dealer installed I guess that means I have a expansion valve too. where might that be located on a 89 Ranger.
Thanks..............................
Thanks
LordVngr is offline   Reply With Quote
Old 07-17-2008, 12:15 PM   #2
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
It looks like you have a stock evap box.
I wouldn't trust hose clamps on an A/C. You can easily get 250 PSI in there, and the pressure relief valve is supposed to be set at 450 PSI even for R-12.
I'd suggest replacing the compressor and lines. The evap looks stock; I can't tell about the rest.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
