| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: pleasure and work
Rep Power: 0 ![]() iTrader: (0)
1990 Ford Ranger 2.9L 5 speed standard 4x4 The Drivers side rear brake continues to lock up when braking. I have changed the slave cylinders and shoes, had the drums turned, bleeded the brakes. Brake fluid does not come out very fast when bleeding. Anyone know if the ABS valve needs to be changed? or is it best to just bypass it all together? Maybe it a master cylinder problem too?
Tweet
#2 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
Rep Power: 10 ![]() iTrader: (28)
Check your Ebrake cable. They tend to seize up and not release all the way.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall. http://www.therangerstation.com/foru...ad.php?t=21890 1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now... 1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only. |
Tweet
#3 |
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Rep Power: 21 ![]() iTrader: (0)
And there is only one rear ABS valve. It will affect both rear brakes the same way. Same deal with the master cylinder.
Make sure your hard line has no kinks or dents between the junction on top of the pumpkin and your wheel cylinder.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage. 1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles. 1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
