| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Rep Power: 12 ![]() iTrader: (0)
Reading through the TRS library about extended brake hoses, and the bottom entry from "Bob" has two part numbers.
Raybestos BH 38622 BH 38623 These cross over to Autozone's Brakeware numbers: 70053 70054 These hoses are 26" long and replace the original front hoses. ![]() ![]() Now I need to cut the brackets off (I do not know what vehicle these are for!!!), and get them on the 'Hog...
Tweet
#2 |
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Rep Power: 18 ![]() iTrader: (38)
These just extend from the stockers?
How much do they extend? You could possibly use those brackets to keep those lines out of the coil.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark. Giddywomp Offroad & Fab
Tweet
#3 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Stock hoses on my 90 Ranger 4x4 were 18". These replace them completly and are 26" long. The stockers were like limit straps with 6" of lift, so we needed longer. Don't have the scratch for stainless braided hose right now.
These are 26" long, and we will be moving the hard lines to behind the F250 shock towers we added. With all that, we are hoping there is enough length in the lines for all the extra wheel travel we added with extended radius arms. Those brackets aren't crimped to the hose, they are GLUED!!!! And there won't be anything to bolt them too. I guess I'll just cut off as much of the bracket as I can and leave the rest as a sleeve of sorts. |
Tweet
#4 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
They are chevy 1500, 2500 brake front flex lines. I'm running them aswell for extended lines, they're nice and long and cheap. I just yank the metal brackets off by hand or pry it open abit with a screw driver and they come right off.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock Last edited by Sasquatch_Ryda; 07-06-2008 at 01:25 AM. |
Tweet
#6 |
Year: 2003
Make: FORD
Engine: 4.0 SOHC
Class: 4x4
Awesome!
I knew the ones in the library are two pieced together. Thanks
__________________
Tweet
#7 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
I use the 2 piece ones from the tech library, have not had any problems. Can also use the top hose from the tech library to extend the rear hose as well.
__________________
HE WHO DIES WITH THE MOST TOYS WINS |
Tweet
#8 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
I just have a "thing" about too many connections for fluids. Can't see adding more joints to leak. And I still need to move the lines to behind my F250 shock towers...
Tweet
#9 |
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Hunting
Rep Power: 11 ![]() iTrader: (2)
These lines will work for any Ranger?
How about a 94 4x4 w/ a 4.0? Or do they only work with the pre 93 model rangers? |
Tweet
#10 |
Make: Ford
Class: 4x4
Any of the models
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#11 |
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Hunting
Sasquatch
How does the drivers side hookup? l have a connection point with two steel lines connected and the hose going to the caliper (3 lines total) l cant see how the screw in end is suppose to work with this connection point... any thoughts? |
Tweet
#12 |
Make: Ford
Class: 4x4
I'll snap a picture of what I did with mine there. I'll post it later.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
