Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 06-27-2008, 04:27 PM   #1
napolron
napolron is on a distinguished road
Default Hurst shifter questions
Ok So I just bout an '08 ranger with a 4.0 and 5 speed, with 200 miles on the clock I ordered my hurst shifter. The shifter went in perfect, shifts great and sounds good when shifting. My problem is in third and fourth gear the stick rattles like crazy. First, second and fifth are nice and silent. There is a bit of play in the stick in the center. I dynamatted around the shifter and did my best to mute most of the noise but its kinda irritating to drive around with the windows up and unless Im keeping pressure on the stick it just rattles like crazy. Anyone else have a similar problem? It makes an aweful lot of noise for a $200 shifter. I had a billet plus in my mustang and loved it so thats why I ended up buying another hurst.
Any info would be appreciated.
napolron is offline   Reply With Quote
Old 06-28-2008, 10:03 AM   #2
racsan
racsan's Avatar
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
racsan has a spectacular aura aboutracsan has a spectacular aura aboutracsan has a spectacular aura about
Send a message via ICQ to racsan Send a message via AIM to racsan Send a message via Yahoo to racsan
Default
yeah, they aint as quiet as the stock unit, look at how the stock unit was made, it effectivly cancelles noise and is better insulated. make sure your stop bolts contact the shifter stub properly. dont preload them. you want it to be fully in gear. mine is the most quiet in 5th. its not as bad as it used to be after 2 years (about 20-30 K miles) of useage but its a definite improvement over the stock setup. i didnt use any insulation around the shifter under the boot. i figured id hold heat in and id rather have a little noise than cause a problem due to retaining heat.
________
Honda CL450 history
racsan is offline   Reply With Quote
Old 06-30-2008, 07:32 AM   #3
napolron
Default
I figured a certain amount of noise, but this thing just rattles bad when its in the center gears, thankfully in 5th gear cruising its nice and quiet but around town being in 3rd and 4th its almost unbearable unless I have the radio up or windows down.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
