| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 2002
Make: ford
Model: explorer sport
Engine: 4.0L
Class: 2wd
Used For: everything
Rep Power: 11 ![]() iTrader: (0)
ok ive searched and read the tech library and couldnt find an answer. where is and how hard is it to change a freeze plug (will i need to jack it up? remove any parts? etc.) on a 2.3l...its leaking from the back of the engine on the passenger side (so it looks like)...its not over heating while driving and just dripping after i stop...i think if i fill the radiator tomorrow morning i can make it to work and back...a few years ago this happened to my truck, i let a buddy borrow it and a freeze plug blew and the idiot drove it from the store "pegged out hot" with water pouring out...i cant afford to fix another warped head, so any and all help will be greatly appreciated.
thanks again drakezilla
__________________
Confucius Say, "Man who goes to bed with itchy butt, wakes up with stinky finger" |
Tweet
#2 |
First of all why call it a freeze plug??? It's not there for any purpose other than access to remove casting sand.The last thing the plug would do is act as freeze protection.
Now if it is a leaking core plug you need access to both remove it and to hammer the new sucker in so once you do locate the leak you will know what needs to be done.
__________________
Head of the department of redundancy department |
Tweet
#3 | |
Year: 1994
Make: FORD
Model: RANGER SUPER CAB
Rep Power: 14 ![]() ![]() iTrader: (1)
Quote:
Tweet
#4 | |
Year: 1994
Make: FORD
Quote:
Tweet
#6 |
Year: 1994
Make: FORD
http://autorepair.about.com/cs/gener.../bldef_233.htm
check that link, i aint saying they are 100% effective, but if you dont know how to keep your antifreeze mixed properly and it freezes then its your own fault if the block or head gets cracked. bottom line is the guy has one leaking and needed to know how to stop the leak, not how to stop his block from cracking in the cold. |
Tweet
#7 |
Junior Member
Year: 2002
Make: ford
Engine: 4.0L
Class: 2wd
ok found it...friggin lil pin hole...its dead center passenger side too hi to get to underneath, too low to get from the top... but i can see it clearly right between exuast mainifold (if thats the proper term these days.. i dont want to offend anyone) guess my feet will be in the air hangin over fender tryin to get that lil sucker in there...wish me luck thanks again
__________________
Tweet
#8 | |
Year: 1994
Make: FORD
Quote:
smear some jb weld on the plug to get you a little more time lol. |
Tweet
#9 |
Junior Member
Year: 2002
Make: ford
Engine: 4.0L
Class: 2wd
hmmm think mighty putty would work???????? lmao j/k
__________________
Tweet
#11 |
Junior Member
Year: 2002
Make: ford
Engine: 4.0L
Class: 2wd
lol thats funny...im known as the jb weld king at work...i wont do it but sounds like a very good idea
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
