t-case for b2
Broncoking
10+ Year Member
i have a electronic t-case and a 5 speed mitsu. will a manual t-case from an automatic b2 bolt right up ? please help cuz these electronic t-cases really suck.
Brad
Yes, It is a direct bolt in. Just need the correct shift linkages for the transmission your using.
So all i need is the t-case and the shift linkage from the doner?
where you located?
I have a 1350 and front driveshaft from a 86 b2
As long as your truck and the doner have the same transmission. There are a number of different linkages.
