| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
I got my truck all together and I think I cured the oil pan leak.
Now the tuning. I'm up to #67 jets and it still seems to be running lean. I checked for vacuum leaks and don't seem to have any. I've rebuilt the carb twice and made sure all passages were clear. I'm running headers and a 10" air filter. Just seems like a lot of jet for this little motor. Is anyone running bigger than #67 jets in their 2.8 with a 2 barrel holley? Al |
Tweet
#2 |
Year: 1983
Make: ford
Model: ranger xlt
Engine: 2.8l durasparked rice killer
Class: 2wd street
Used For: building carbon debits
Rep Power: 26 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
dang?i'm using #57 jets,i started at the #61 that came with the holley 350cfm carb and it ran rich until stepping down.are you setting the idle speed richness by ear or with a vacuum guage?
my plugs were sooting up with #61 and#59 jets,they went clean at #57 jets.
__________________
fairtax.org fairtax.net Colt .45,don't leave home without it. What's in your holster? I don't hate often but when I do it's libtards. I may be found dead in a ditch,but i'll be laying in a pile of brass. |
Tweet
#3 |
Junior Member
I'm setting the idle richness by ear but that shouldn't effect how it runs at speed, would it?
My plugs are coming out spotless. I found I had a set of 68s, I put em in and will drive it with those tomorrow. It seems to be getting better as I go richer. I forget to mention, I'm at 3400 feet elevation. I know that used to make a big difference jetting my RZ350 Yamaha. I never could get it perfect here. Al |
Tweet
#4 | |
Year: 1983
Make: ford
Model: ranger xlt
Class: 2wd street
Quote:
been using the holley tuning site too.i may go up to #58 for the hell of it,see what happens.got a pair on the bench.
__________________
Tweet
#6 |
Year: 1983
Make: ford
Model: ranger xlt
Class: 2wd street
manual also says they are calibrated for 70 degrees at sea level,we are more like 80 to 96 this time of year.
__________________
Tweet
#7 |
Junior Member
I may have figured it out.
Seemed to be an obvious vacuum leak. Well, I found there is a hole under a plate the choke mechanism is mounted to on the carb. That hole runs right to the base of the carb. I imagine it is for some sort of automatic choke so I plugged the hole. More to come once I run it. Hopefully it will be running very rich now. Al |
Tweet
#8 | |
Year: 1983
Make: ford
Model: ranger xlt
Class: 2wd street
Quote:
good luck!
__________________
Tweet
#9 |
Junior Member
Yeah,
that's been a lot of help. After finding that hole I checked that and he mentions converting from auto choke to manual you need to plug that hole. I didn't convert it. Bought carb used as a manual choke carb Still runs like crap at full throttle. more stuff to check. |
Tweet
#10 | |
Year: 1983
Make: ford
Model: ranger xlt
Class: 2wd street
Quote:
__________________
Tweet
#11 |
Junior Member
No,
I checked everything; Compression is between 124.5 and 125 all cylinders (motor just rebuilt) Vacuum is high (I forget the numbers) Vacuum advance from carb and advancing timing is working New cap, rotor and plugs I finally bought new spark plug wires (they usually are a waste of money as is the case this time, runs the same) I'm pretty sure it's the carb as it's still running lean with #70 Jets. I will try an old stock carb to see if it'll run full throttle with that. If that doesn't seem to do it I'm going to try an old electronic box that used to work in my Jeep. Hopefully this weekend. Any other ideas? Al
Tweet
#12 |
Year: 1983
Make: ford
Model: ranger xlt
Class: 2wd street
i'm out of ideas at this time.mine is starving for fuel,put new pump on,new hoses to tank(that was fun) and still trickles fuel to carb.have a clear in line filter just before carb.
guess it's time to look at the fuel pickup in the tank. drop that guy a line at the tuning site maybe?
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
