- Sep 8, 2007
- Automatic
___
___
___
From what I can see.. nothing has been modified by the pervious owners.. why would someone remove it? is that something that is done on the rangers? sounds like nothing but trouble.
160 deg is too low for EFI. Remove it and put the stock 195 deg back in, or stock up on catalytic converters.
If you're concerned about cooling, put the stock fan back in. If you're trying for power, you're barking up the wrong tree (coolant temperature isn't the same as air charge temperature, especially with an unheated intake).
