Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-10-2007, 04:08 PM   #1
smuj_2006
Junior Member
Year: 1994
Make: Ford
Model: Ranger Supercab
smuj_2006 is on a distinguished road
Default Transmission Swap Auto to 5speed
i have a 1994 ranger 4.0 4wd with the A4LD. Im swapping in a 1988 5speed in it and was wondering if someone could tell me if i have to change the crank at all or even give me step by step directions and a list of what i need. thanks.
smuj_2006 is offline   Reply With Quote
Old 09-10-2007, 04:36 PM   #2
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
No, the crank is the same.
The flywheel is very different. So is the starter. Obviously, you'll need all the clutch parts. Not so obviously, you'll need a brake pedal and a "hump plate."
Not all 1988 5speeds will fit a 4.0L. Only those from 2.9Ls.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
