| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Alternative Fuels & Energy For discussing topics such as ethanol, hydrogen, biodiesel, propane, natural gas, solar, electric, etc. |
Thread Tools | Display Modes |
#1 |
Year: 93
Make: FORD
Model: EXPLORER
Rep Power: 12 ![]() iTrader: (0)
I think I have found something you will like look at this and let be know what you think,just trying to help all my friends out on here.
http://www.runyourcarwithwater.com |
Tweet
#2 |
I would reeeaallllly like these products to work but unfortunately they probably don't.
The reasons they probably don't are as follows. The hydrogen converter relies on the cars battery to supply current. As the battery drains and the voltage drops the car's voltage regulator will kick in extra coils in the car's alternator to create more current to charge the battery. This increases the altenators load on the car's engine. Unfortunate the extra load on the engine will be far greater than the extra power created by the hydrogen. This is because of the following: 1. The electrically energy produced by the alterator is less than the energy drain on the engine. 2. Energy is again lost converting the electricity energy to chemical engery stored in the HHO. 3. Energy is again lost converting the chemical energy to mechanical energy when the Hydrogen is burnt. As you can see there is a net energy loss at each stage and the system is draining energy from the car. Sad, but unfortunately true. This can not work! because the law of conservation of energy states that the total amount of energy in any isolated system remains constant but cannot be recreated, although it may change forms, e.g. friction turns kinetic energy into thermal energy. In thermodynamics, the first law of thermodynamics is a statement of the conservation of energy for thermodynamic systems, and is the more encompassing version of the conservation of energy. In short, the law of conservation of energy states that energy can not be created or destroyed, it can only be changed from one form to another.
__________________
"Buy once, cry once. Buy cheap, buy twice." Last edited by OilPatch197; 06-12-2008 at 09:07 PM. |
Tweet
#4 |
Odd One
Year: 1987
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() iTrader: (17)
do a search, this has been covered here a couple times before. there's a certain few that will swear up and down that it wont work, and there's a few that would bet their life it does....
__________________
1987 Ranger Supercab STX, 4.0/M5OD/BW1350 4.10LS, 2" Lift, Cut Fenders, 33's 1987 Thunderbird Turbo Coupe (Mostly stock, for now...) 1991 Escort GT (Daily Driver) Past: 87 Supercab, 87 Longbed, 89 Shortbed, 96 Explorer Sport |
Tweet
#5 | |
Year: 1994,1965
Make: Ford
Model: Ranger supercab, Mustang Coupe
Engine: 4.0, 302
Rep Power: 13 ![]() iTrader: (1)
Quote:
And as i understood it the hydrogen only assists in making a more complete burn of the gasoline. Having that set up on there doesnt seem like it would be much different than having off road lights on or something similar. But thats just my thinking and im no scientist.
__________________
http://www.cardomain.com/ride/2949161 http://s215.photobucket.com/albums/c...t=40d9ecc0.pbw Specs: -'94 Ext. Cab 4x4, 4.0l 5 spd. 31x10.50x15 Wrangler AT/S. Warn Manual hubs. A tool box! -Tube bumper, needs welded to mounts -40 series Flowmaster. -5.5" Superduffcountry lift |
Tweet
#6 |
Premium Member
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Used For: Project, DD
Rep Power: 23 ![]() ![]() ![]() iTrader: (2)
You can run your car off of water but it has to be set up differently I think the image is not very clear at all.
I have a friend that gets around 50 mpgs out of his little 3 cylinder geo metro. You put the water in the intake through an injector not mix it with the fuel otherwise it won't burn/ignite. The water will turn into a vapor and expand in the cylinder when the gas is ignited, water in gas form expands alot so it will force the piston down fastercause it expands more then the regular gas. That is where the power is gained and your gas mileage will go up. WWII planes did this at take off and stuff. That kit looks like it is designed to convert water into hydrogen and oxygen then burn the gasses which is really hard and expensive , and not very efficeint at all.
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights. 84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers. |
Tweet
#7 |
HEY!!! Those are the same exact plans my friend gave me a copy of, who wants a copy?
OilPatch, are really serious? I can take my trucks battery, and let it run all night producing hydrogen, and still have more than enough power left in the battery to start the truck. Have you not ever done this to remove rust? Making hydrogen is very old news, it is just being made more efficient now. And if you watch the video, the one on that site where you see the man with a torch, he is the inventor. He converted his car, it was on the local news, because he is\was a local trying to sell his water torches. |
Tweet
#8 | |
Year: (formerly) 200
Make: Ford
Model: Ranger XLT
Used For: She's gone. I am diesel huntin'!
Rep Power: 22 ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
I have not seen this in a car personally but i have seen this type of setup running a torch on a co-workers deck. he is another "theorist" like some here and he jumped on this the second he heard about it years ago. Given the small size of what he built (12x12x12) and the fact that it was emitting a constant 6 inch flame, I would say it is plausible to build a system like this that could make a major difference in gasoline usage or even possibly, after much trial and error, power a car. |
Tweet
#9 |
Year: 1994,1965
Make: Ford
Engine: 4.0, 302
Oilpatch didnt really prove a net loss. He showed that there is potential for loss, but no numbers on the loss, or numbers on the gain, so how can he say there is net loss?
__________________
Tweet
#10 |
Year: 1989
Make: Ford
Model: Ranger
Rep Power: 13 ![]() iTrader: (0)
Jewelers have used torches with hydrogen generators for years for fine work. If you want large amounts of hydrogen do what they did during the civil war to generate hydrogen for observation balloons. Drop some zinc (or magnesium powder) into hydrochloric acid and large amounts of hydrogen are generated really fast. They could fill a large balloon in very little time with this method.They ran the resulting gas through a crude filter to remove impurities on it's way to the balloon.
You could probably use magnesium castings, etc. which are plentiful in scrapyards.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel. |
Tweet
#11 |
I know once I have time to sit down and really study these plans, I figure it will be easier to put together than it looks. I still have to get over to my buddy's house and look at what he has, his might be simpler.
This one has an awful lot of Electronics to it, from what I have seen so far it has a window detector with a trigger, but the schematic shows it going to a connector which means I need to look at the other part of the print. I guess I should really print it out, probably be easier to read. I will check with my friend ASAP, he is supposed to be building a test kit out of his plans and wants to use the Ranger as a test for 30 days. If it is done (I doubt it, he works like 12 - 14 hr days) I will post here as well. I believe, if anything, it will increase about 5mpg, that is me though. |
Tweet
#12 | |
Quote:
If ya did that, then you would have to compress it into a container, I would then suggest you carry a full bag of miracles with you. If that bag is empty, stay home, that much hydrogen being compressed would be worse than the Hindenburg disaster, you would essentially have a very large bomb installed to your vehicle, just waiting for a wreck. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
