is it a manual tcase? if so pull up on the leaver towards you an thats 4x4 HIGH once you reach that spot push it out towards your lefta little an pull up a lil bit more an thats 4x4 LOW hope this helps if its auto an anythingling like my 95 i just push my clutch in an hold the brake an turn my elec knob to 4x4 high an it goes then to 4low..
After engaging the manual t case then i take it he goes out locks in the hubs and then is it completely in 4wd? or does he need to go in reverse or something to fully lock everything?
just put the t-case in 4 high or 4 low and lock the hubs, you are probably thinking more about auto hubs (back up to unlock them) but on that truck they should be manual
