A\C cuts out after 5 secs
gilante
10+ Year Member
I have a 95' Ranger XLT 2.3L. My AC does not work. I have noticed though that when I start me truck with the AC already on, it starts to blow cold air for about 5 seconds and then cuts out. I have been told that this may be a pressure switch gone bad. I'm sure someone has had the same problem I have and where this pressure switch is if that's the case.
Your problem may or may not be someone else's problem. You need to find out what the pressures are doing to diagnose this.
