Over-active ABS?....
cr_the_machinist
15+ Year Member
⭐Supporting Member
Dexter, Michigan
My ABS is starting to really piss me off! Whenever I make a sharp turn while using the brakes at a low speed (like 5mph or less) my ABS will sometimes kick in. It really starting to bug the heck outta me. Has anyone ever experienced this problem before? Any easy fix to it or is it just the nature of the beast?
if its the front pull the sensors and clean them and clean the hole where they go. if its the rear clean the sensor(on the pumkin) .while ur at it pull the diff cover and clean out with brake fluid cleaner, i have heard that a lot of small metalic flakes can throw off the sensor at low speeds. good luck.
