| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1984
Make: Ford
Model: Bronco ll
Engine: 2.8 duraspark
Class: 4x4
Used For: everything
Rep Power: 11 ![]() iTrader: (0)
Hey Jim,
I've gotten a "vBulletin Message" "The server is too busy at the moment. Please try again later." 3 or 4 times in the last 2 days. Saw a post where you mentioned checking the error log and figured I should let you know. Type at ya later. Thanks!
__________________
If it don't fit,force it. If that don't work get a bigger hammer! 84 Bll 2.8L duraspark, rv cam, cowl induction T-K 5, 31x10.5x15 manual T-case and hubs |
Tweet
#2 |
Model: 89 bronco ii
Class: 4x4
Used For: going inappropriate places
Rep Power: 29 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (4)
im constantly seeing that message, more the last few weeks than i ever did, usually around 15-20 times each week
__________________
97 Jeep TJ. 6" lift and 33's. 79 F150, restoring. 90 Mustang 5.0L sold: 89 BII, lifted, bumpers, winch, and stuff "Dont know how to drive automatic"- Chance. RIP Buddy. |
Tweet
#3 |
Building another truck
Year: 1983 & 1996
Make: Ford
Model: Ranger
Engine: 5.0 / 4.0
Class: 4x4
Used For: Dedicated trail rig!
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I made a change in the settings. Please let me know if it continues.
Thanks.
__________________
Some people are like slinkies -- not much good for anything, but they bring a smile to your face when pushed down the stairs. Check out my Blue Oval Militia Profile HERE Vote For TRS In Top 4x4 Sites |
Tweet
#4 |
Model: 89 bronco ii
Class: 4x4
thanks Jim, I havent seen it now in a while
__________________
Tweet
#5 |
Year: 1994
1985
198
Make: Ford
For
Model: Explorer
Ranger
Ranger
Class: 4X4
Used For: DD/Play
Rep Power: 12 ![]() iTrader: (0)
All times are GMT -4. The time now is 08:32 PM. Currently Active Users: 115 (46 members and 69 guests) |
Tweet
#6 |
Model: 89 bronco ii
Class: 4x4
my server was busy just then
__________________
Tweet
#7 |
Year: 1983 & 1996
Make: Ford
Model: Ranger
Engine: 5.0 / 4.0
Class: 4x4
Ok. I just increased the number of MaxClients. Should help.
__________________
Tweet
#8 |
Model: 89 bronco ii
Class: 4x4
thanks Jim
__________________
Tweet
#9 |
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (5)
Interesting..
I got the message at 8:32/33 PM GMT -4. I think it's something more lower level that Jim might not have any control over. Like a cronned script that's running at 8:30 that's causing the CPU usage to spike. But I don't know honestly, that would be my first guess though. It generally clears up within a few minutes, it's not a big deal. IMO. Pete |
Tweet
#10 |
Year: 1988
Make: Ford
Model: Bronco 2
Engine: 2.9
Class: 4x4 Off Road
Used For: DD
Rep Power: 12 ![]() iTrader: (3)
i got it last nite for about 30 mins...like 25-30 times!!
__________________
'88 B2, 2.9, 4x4, D28 3.45 Front An Rear, 1350 Auto T-Case, Warn Manual Hub's, 58mm TB Mod, Hurst Shifter, 10 seris Flowmaster & 1 cat, Connex 33HP Cb, '93 Chevy Buckets, K&N Cold Air Intake, Black Push Bar, Black Eagle Eye 150w Off Road Lights, 2'' Coil Spacers, 3 '68 F100 Leafs Out Back, American Racin Black Steelies Spinnin' 31'' MTR's, ~MOD'S TO COME~: Get X-Shaft Cut, Balenced, And Installed!! |
Tweet
#11 |
Year: 1997, 2005
Make: Ford
Model: Ranger STX, Ranger Edge
Engine: 4.0, 4.0
Class: 4x4, 2WD Street
Used For: Offroader, Daily Driver
Rep Power: 15 ![]() iTrader: (0)
Just seems like something that happens from time to time. The error times you were getting are evening times which are when the most users are logged in, hence when the server is the busiest. Sometimes the server just gets a little overloaded and has to catch up. This isn't the only site that happens on.
__________________
1997 Ranger STX 4.0L 4X4....... 200,000 miles and counting 4" Superlift w/ Pro Comp shocks, 33" Mud Terrains, 4.56 Gears, Iridium plugs, Warn manual hubs, Flowmaster 40 "I can predict the motions of the cosmos but I can not calculate the madness of the people." - Isaac Newton, 1727 |
Tweet
#12 |
Year: '93
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4 Offroad
Used For: DD'er and weekend wheeler
Rep Power: 15 ![]() iTrader: (2)
Well, seeing as it is what this thread is about, I'll post it here.
I have never gotten that messge until a few weeks ago. And starting on Friday or Saturday (28th/29th) the site will be working just fine, and then I get that message.. Click refresh, get it agian, try the main forum page, up it comes agian. TRS home and all that works, but that isn't part of the forums either. This goes on for 10-20 minutes of not being able to view anything on the forums, and then it goes back to working for a while. This has happened about once every day since (a couple days it happened multiple times, and others not at all).
__________________
'93, 4x4 Ranger, ext. cab, 4.0L, M5OD 5spd swap, D.D. Doubler, manual hubs, Explorer leaves/ 3" coils, CB, 3" body lift, and half doors. DD: '99 3.0l swapped Contour SVT |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
