| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Used For: Winter driving
Rep Power: 12 ![]() iTrader: (0)
My 94 4.0L is knocking, and it's coming from the belhousing area. I used a stethescope and it's loudest where the starter goes into the housing. What could this be? I've driven it like this for about 4 months now, so if it was a rod it would have blown by now. It's barely noticable when cold, but gets louder when warm. I can really hear it between 2500-3000rpm. It sparks-knocks like mad too all the time too. I think I'll pull the motor next week, but is there anything I should look at first? TC? Flexplate?
Tweet
#2 |
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Rep Power: 21 ![]() iTrader: (0)
I'd be concerned about the flexplate being loose or partially broken.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage. 1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles. 1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2. |
Tweet
#5 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Well, I'm pulling the motor this week. I have a lot of the stuff loose, but I can't get to some of the belhousing bolts, or the TC bolts. Ideas?
Tweet
#6 |
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
For the bellhousing, use lots of extensions and a U-joint.
For the torque converter, rotate the crank with a ratchet on the harmonic balancer bolt.
__________________
Tweet
#7 |
Year: 84
Make: ferd
Model: 2-B2s one is stock
this style works best, the other one tends to lay over and strip things. Sear's has a good-nuff one for a few bucks. stay away from the car parts stores especialy for these. cheap ones are less dependable that cheap sockets.
http://cgi.ebay.com/ebaymotors/PRO-9...spagenameZWD9V Bob |
Tweet
#8 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Well, I got the motor out and apart. So far, the crank is scarred, but nothing else. THe pistons look good, rods good, heads fine, no cylinder ridge (after 132000 miles), so I can't figure out what took a chunk out of the thrust bearing.
I'm going to run the 410 Comp cam in it, as long as I have it apart. Should I do anything else, like head porting, larger injectors, headers, ect? This is mainly a winter truck, but it's in really good shape for a 94. |
Tweet
#9 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Well, I can't figure this out. I'm thinking of just buying a reman shortblock and hoping it will take care of it. I really don't know what to do yet.
Tweet
#11 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
A new oil pump was in the plans. I always replace the oil pump when I have a motor apart.
Tweet
#12 |
Junior Member
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
I've got the parts to put my 4.0L back together. Problem is, I don't feel that good about reinstalling it if I didn't find the problem. I can't find a darn thing wrong with it! There's got to be a cause as to the knock.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
