EB SAS C-Bushing Degree ???
UrbanRedneckKid
15+ Year Member
Solid Axle Swap
Cass Co, Missouri
I'm in the middle of aquiring all the parts for my SAS (EB44) and I came arcoss the C-bushings. Using 5.5 Progressive rate springs and 78-79 4" drop radius arm brackets with factory EB radius arms. What degree C-bushings should I buy?? My truck is a reg cab long bed 4.0 if it matters.
for what everyone has said, with that much lift you will definitly want to go with the 7 degree bushings. I'm using the stock bronco coils for a while and I'm using 4 degree bushings. I know a couple people using the 3.5" coils and they are glad they went with the 7 degree bushings.
I'm using 7 degree bushings with my 3.5" coils with stock 78-79 drop brackets. I would still use 7 degree bushings even with 4" brackets just because your going 5.5" of lift.
Cool, thanks for the input guys:icon_thumby:, I'll get the 7deg ones.
Do you guys recommend any certain company's bushings?
A bunch of different companies sell them, but polyurethane is polyurethane. It doesnt really make a difference who you buy them from. Mine were from energy suspension just because that's what the local parts house carries.
