Well Im switching over to auto so I had planned on using the explorer column, but it isn't fitting as I thought it would. Maybe I do need a ranger column???
I had to move the mounting bracker on the column up since the whole column seems to be a hair longer than the ranger column. And there's no room to connect the ignition switch pigtail in either, so might have to make a trip to the local yard and see what i come up with.
Old thread but I’ll give it a try. I have a 85 ranger, I’m doing a 302 automatic swap. I would like a tilt automatic shifter column with cruise. Does anyone know what columns will work? What year Bronco II’s Rangers?
