QUOTE(daisy0504 @ Jul 6 2007, 05:33 AM) *From my experiece all add a leaves are about the same unless you get a long or short leaf. The short ones are are stiffer than the long ones. If you were to take the time to swap an explorer main leaf it would be just as easy to swap the whole leaf pack. Which would give you lift as well. But the cheapest route would be the add a leaf and if its just for mud you wouldnt be too worried about a flex inhibiting add a leaf.
X2. I would go with long add-a-leaf or the whole Explorer pack personally. You'll get the best ride, the springs will last longer without going negative arch at the ends due to short add a leaf.
