Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-29-2008, 07:49 PM   #1
Zorro
Year: 1994
Make: Ford
Model: Ranger 4.0 4x4
Zorro is on a distinguished road
Default Connecting clutch line to clutch slave?
Is there a trick to this?
I got a new clutch kit, including the slave, am re-using the old line and male connector.
I just spent 15 minutes trying to get it to snap, to no avail. I don't even think it goes in enough to snap anyways.
I really wouldn't want to break the female connector on the slave and have to take it all apart again to fix it.
Maybe the old O-ring on the male connector has become too fat (yes, I was re-using it because I had forgotten about the new one that comes with the kit ... will change that)? Maybe the plastic ring is preventing things? Should I open the bleeder to relieve the pressure as I try to connect the line?
Zorro is offline   Reply With Quote
Old 04-29-2008, 08:21 PM   #2
rboyer
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.hoe
Class: 6 inches!
rboyer is on a distinguished road
Default
Shouldn't have to open the bleeder. Put on the new o-ring, rub some fluid on it, and jam it in there.
rboyer is offline   Reply With Quote
Old 04-29-2008, 10:21 PM   #3
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
If you open the bleeder you will have to bleed the system.
Did they give you the correct slave? It should go in rather easily and lock into place.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop.
Jspafford is offline   Reply With Quote
Old 04-30-2008, 09:40 AM   #4
Zorro
Year: 1994
Make: Ford
Default
Oh shit.
I just looked at my slave kit. It says it's for 93-97 trucks. My Ranger is a 94, but the Exploder the clutch line is from is a 91.
Are those f*cking quick connects different from year to year????? Dammit.
Maybe replacing the clutch slave wasn't a great idea after all.
Old 04-30-2008, 09:53 AM   #5
mjonesjr
I dance with the Devil...
mjonesjr's Avatar
mjonesjr is on a distinguished road
Default
All '91+ Explorers & Rangers use the same hydraulic clutch line. Even the '97+ Rangers use the same clutch, clutch hydraulic line, pressure plate, and slave cylinder.
There might be something in the end of the line or slave cylinder preventing the line from going in.
__________________
I shall not surrender...
I shall not retreat...
I will stand here and fight...
Or I will stand here and die!
All men are created equal, then a few become firemen.
Support Our Troops!
mjonesjr is offline   Reply With Quote
Old 04-30-2008, 09:54 AM   #6
Zorro
Year: 1994
Make: Ford
Default
The Explorer is a '91. Check my "construction" thread, they're far from identical after all.
I feel like a jackass for not checking it before it was all on the truck now.
Old 04-30-2008, 09:54 AM   #7
mjonesjr
mjonesjr's Avatar
Default
The '91 Explorer is no different. They all use the same setup.
I put a '03 Ranger clutch, slave cylinder, and M50D-R1HD in my '97 Ranger when I did the manual transmission swap.
__________________
Support Our Troops!
Old 04-30-2008, 10:13 AM   #8
Zorro
Year: 1994
Make: Ford
Default
Depth is identical, as well as inside diameter. What may be wrong is the little pin in the middle ... maybe it's bigger?
I don't know how identical it is, but I can tell it doesn't fit. And I've actually pried it!
Old 04-30-2008, 10:22 AM   #9
thegoat4
thegoat4's Avatar
Year: 1998
Make: Ford
Model: Ranger
thegoat4 is on a distinguished road
Default
How hard did you have to push on the transmission to get the bell housings to touch? If you had to push hard, or draw it up with the bolts, (that's a no-no) you've got pressure on the clutch diaphram, which means pressure in the slave, which will make it damn hard to install the line. It will feel like it simply does not fit. Either back the tranny off again to relieve the pressure and connect the line before bolting it back up, or crack the bleeder and let the pressure off the slave slowly. if you crack it slowly and pay attention, you won't wind up having to bleed it.
thegoat4 is offline   Reply With Quote
Old 04-30-2008, 10:45 AM   #10
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
NO NO NO NO NO!
There are TWO distinct quick-connect fittings. They are similar, but do NOT interchange.
You need a '91 slave.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 04-30-2008, 11:28 AM   #11
Zorro
Year: 1994
Make: Ford
Default
Urgh.
This is what I feared.
Will try to find a Ranger master at the scrap yard. Wish I could've planned it and not wasted any time.
Old 04-30-2008, 09:28 PM   #12
rboyer
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.hoe
Class: 6 inches!
Default
Since you're this far into it, wouldn't it just be easier to get the hydraulic line that matches the slave?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
