Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-28-2008, 02:17 PM   #1
neilk
Junior Member
Year: 1998
Make: Ford
Model: Ranger 4x4 5.0
neilk is on a distinguished road
Default tranny not shifting
I just did a V8 swap in my Ranger from a Mountaineer, runnin great, goes into drive and reverse quickly, it just doesn't shift outta first, I am getting codes P0707 trans range sensor low input and P0500 veh speed sensor A malfunction, could there be a conflict between the ranger speed sensor and the Mountys I assume it is located on the rear axle, I changed the nuetral selector switch from the old tranny,,,any ideas? thanks Neil
neilk is offline   Reply With Quote
Old 04-28-2008, 09:18 PM   #2
Bruce
Bruce's Avatar
Year: 2002
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0 SOHC
Class: 4x4 4:10 gears
Used For: Daily Driver
Bruce is on a distinguished road
Default
You dont say what year but i think youd better go back thru the wiring and check to be sure you have all your positive (+) and ground(-) hooked up accordingly on the computer kinda sounds like you may have aground problem and im not to sure about the compatibility of a MLP out of a 4R44E 0r 5R55E and an AODE or 4R70W. Dont know what ya had.
__________________
2002 Ranger Supercab 4x4 4 door 4.0 with 4:10 gears.
Bruce is offline   Reply With Quote
Old 04-28-2008, 09:23 PM   #3
neilk
Junior Member
Year: 1998
Make: Ford
Default
I have a 98 ranger 3.0 AOD, I put in a 5.0 AOD from a 98 Mountie, one thing I noticed is a relay clicking noise under the dash behind the instrument panel when in reverse, wasn't there before, maybe the shift relay doesn't like the 4r70w tranny,,,Neil
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
