no brake lights unless headlights are on
ja8008
I have a 1994 Ranger supercab 4wd. I only have working brake lights when the headlights are turned on. Connection and wires check good. Bulbs are new. Headlight switch checks good. Headlight alert doesn't work either. Previous owner removed door jamb switches too so there's no dome light when door is open. Key in ignition alert doesn't work either.
I don't know if these are all connected or not. Like they're in the same circuit or something?
Any ideas what might be wrong? I feel like I'm overlooking something.
I've almost been rear ended many times because my rear brake lights don't work unless the headlight switch is pulled all the way out to activate headlights. :sad:
Sounds like the previous owner did some handy rewiring to his liking and messed some things up along the way. The brake lights typically work even when the ignition it turned off.
1994 has separate brake light bulb and turn signal bulb so wiring is fairly straight forward.
Same fuse powers brake light switch and headlight switch
Does anyone have a wiring schematic for the brakes, door jamb wires, etc.....
Also, how do you access the wires or find the plug for the door jamb switch?
Exactly. He also removed some things and I can't find the wires that go to them. I really need help. I'm looking to make my Ranger really good and strong. Yay, I like it a lot. Looking to improve it but first I need to make it safe.
Reads like you could use the Electrical and Vacuum Troubleshooting Manual, or "EVTM" for a 1994 Ranger.
Electrical diagrams like I posted above are helpful up to a point but the EVTM lays things out a little different, it is made for service techs to trouble shoot sub system wiring, so has connectors and pinouts.
Check out ebay: EVTM 1994 Ranger
They run about $20, there were some transfered to CD but don't see them any more?
You don't want electrical repair manual or repair manual, hold out until you find the EVTM
And for a 1994 not a 1993 or 1995
Example here: http://www.ebay.com/itm/1994-Ford-R...=true&rt=nc&_trksid=p2047675.l2557&rmvSB=true
And just FYI, local library's often have these, not for checking out though, but you can copy pages you need, or take a picture with smartphone
I'm limited on funds but my hearts in the right place.
The EVTM manuals I've found run from $50- $120 so it'll be a while before I can get this fixed.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Check local library, it is FREE :)
You will be surprised how many tech manuals they will have in print, on CD, in media storage, or in "the cloud"
Original socket for headlight had a burn mark and two pins were not seating right. Some of the pins were broken and weren't making contact properly. So, I replaced the socket with pins and wire. Now I have brake lights working properly.
