Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-17-2008, 04:22 PM   #1
J.HYATT
Year: 2002
Make: FORD
Model: RANGER 3.0 V6
J.HYATT is on a distinguished road
Default '02 3.0 A/c On = Rough Idle
Hi all...
I've got 2002 Ford Ranger Ext. Cab 3.0 v6 automatic. If you put it in gear and turn on the a/c the engine lopes / idles badly. Whenever the compressor kicks in, it drops to 500rpm and tries to cut off. If AC is off, it idles fine.
Any Ideas???
Problem #2: Runs great down the road until you give it gas to down shift while going up hill. It will down shift but it kicks in and out like it's starving for fuel. Fuel Pump??? Filter?
Any info greatly appreciated.
Thanks,
newbie...........
J.HYATT is offline   Reply With Quote
Old 04-17-2008, 04:36 PM   #2
J.HYATT
Year: 2002
Make: FORD
Default
BTW
Scan Tool shows no codes.
Old 04-17-2008, 08:20 PM   #3
bikerboy
bikerboy's Avatar
Year: 2001
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2wd
Used For: Daily driver
bikerboy is on a distinguished road
Send a message via AIM to bikerboy
Default
Check your Idle Speed Motor. It's two bolts mounted on the top of your throttle body. just clean it out with some gum-cutter. Clean your throttle body while you are there. Also when is the last time you did a complete tune-up, including plugs, wires, pcv valve, fuel filter,air filter?
__________________
2001 Ford Ranger
3.0 V6 2WD Auto
Current Mods
Underdog Crank Pulley, Hot Water Bypass Mod , Throttle cable Mod,
Cobra SVT Wheels 245/45R17 Up front, 275/40R17 Out back, 4/5 DJM Drop Kit <===COMPLETE!!!
Pioneer Head Unit, Pioneer 6X8's in the doors , Rockford Fosgate 10" sub
Clear Corners
bikerboy is offline   Reply With Quote
Old 04-17-2008, 08:44 PM   #4
J.HYATT
Year: 2002
Make: FORD
Default
Thanks. I'll give it a try. As for tune up I'm sure its due - just bought it. I got a good enough deal on it to put a little extra in it if needed.
Old 04-18-2008, 10:58 AM   #5
J.HYATT
Year: 2002
Make: FORD
Default
Well I cleaned it and it seemed to help .... for a minute. So I replaced it, Still does the same thing. It won't do it when it first starts up and the idle is higher. What else would affect idle speed with ac on? Would an over charge on the ac system cause it?
Old 04-18-2008, 11:05 AM   #6
Ranger44
Ranger44's Avatar
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
Check your throttle position sensor (TPS). It is strictly a driver input sensor, and affects the fuel injector pulse, something like 500% override, and well if you do stomp on the gas and it's not working properly, it'll basically seem to bog out.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Old 04-18-2008, 01:24 PM   #7
J.HYATT
Year: 2002
Make: FORD
Default
Thanks for the tip. So far, I've replaced the IAC Valve, and the TPS. Neither have fixed the a/c Idle issue. I've also cleaned the MAF. This one's got me stumped.
As for the problem cutting in and out at highway speeds, it's getting worse, so I think it's almost got to be fuel pump/ fuel filter.
Any further idea's on the a/c idle issue. Is it possible to just dial up the idle a few hundred rpm?
Old 04-18-2008, 03:54 PM   #8
Ranger44
Ranger44's Avatar
Year: 2003
Make: FORD
Engine: 4.0 SOHC
Class: 4x4
Default
Have you checked for a binding A/C compressor? It may just be on it's way out. It'd put a load on the engine. Unplug the A/C compressor and see if it makes the difference. BTW, new parts can be DOA. Do you have a manual and multi-meter? I'd actually check the sensors.
__________________
Old 04-18-2008, 07:13 PM   #9
almostclueless
almostclueless's Avatar
Year: 98
Make: ford
Model: ranger
almostclueless is on a distinguished road
Default
Torque convertor clutch problem?
__________________
1. MORE COWBELL!
2. Chuck Norris can win Connect Four in three moves.
3. What the H___ is an aluminum falcon!?!
4. sham....WOWWWW
almostclueless is offline   Reply With Quote
Old 04-19-2008, 07:43 AM   #10
J.HYATT
Year: 2002
Make: FORD
Default
Yea I thought about the TCC. But it down-shifts smoothly and then starts cutting out. Just to be sure, I thew it into neutral and revved it. With out fail, it will cut out at 3100 rpm. I put a fuel pressure gauge and revved it up and the pressure would drop slightly at the same instant it started cutting out. It never dropped below 50psi. I think that's more than sufficient on a flex fuel. If someone doesn't agree please let me know. It would be a releif to know that it's just the fuel pump. I know they're in the tank and it sucks a little to change em, but I'm tired of trouble shooting.
I'm afraid the a/c - idle issue is most likely what was mentioned by Ranger44.
Old 04-19-2008, 10:08 AM   #11
almostclueless
Year: 98
Make: ford
Model: ranger
Default
Quote:
Um, the spec on my 98 is around 70psi.
I can understand why youre tired of troubleshooting.....and you should consider a solid diagnostic by a good dealership. Ends up being CHEAPER than throwing parts at a vehicle.
__________________
1. MORE COWBELL!
4. sham....WOWWWW
Old 04-19-2008, 04:58 PM   #12
bikerboy
bikerboy's Avatar
Year: 2001
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2wd
Default
If you think it might be due of r atune-up then i would do one before you spend more money to have a dealership or personal garage diagnose it. Replace the spark plugs, wires, fuel filter, air filter and pcv valve.
__________________
2001 Ford Ranger
3.0 V6 2WD Auto
Current Mods
Clear Corners
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
