- Aug 15, 2007
- Age
- 60
- Automatic
Will it work on a gen 3? Kit in this case happens to be an older Duff gen1 kit. Thanks.
It should work out ok. The only thing I can think of is that a GenIII is a little heavier than a GenI so the springs may feel a little soft. The pitman arm will be the same, if there were sway bar links and such those may be different between the two depending on the year. If it has radius arms there may be a little legnth difference between the D28 and the D35 but moving the brackets should solve that. That is all I can think of. You should be fine, my lift was from a 94 Ranger and it's on an 88.
Matt
