- Nov 28, 2007
- Automatic
I decided to start practicing some of my welding skills a little more. I wanted to make some sort of tire carrier for my Cherokee, but I don't have a large amount of metal available to me without buying new.
I managed to find some 1/4" stainless steel plating, and some 2" square tubing in the scrap bin at work to play with. After cleaning it up, it's more than usuable. For the rim mount I have a Ranger rear shaft somewhere that should work.
I'll post up some pictures soon. Possibly mid week. Most of the mount is tig'd since I origionally didn't plan on painting it. But since I had to make the upright portion of it out of plain steel I'll be hiting it with primer and bedliner. I'll mig the axle shaft (drilled out and welded to both sides) to the upright for strength, with a gusset on the bottom side.
I'm aiming to have the whole unit with tire to only weight about 100lbs. If I go over it's no big deal. Right now It's only going to have a 235/75R15 but I'm setting the distance for the wheel mount to a 10.50 tire on my AR rims since they will eventually be on the Jeep.
Stay tuned!
Stay tuned!
