| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1990
Make: Ford
Model: Ranger 4.0 XLT
Engine: 4l
Class: 2wd
Used For: 3rd vehicle, Work horse.
Rep Power: 11 ![]() iTrader: (0)
My temperature indicator has been dead since I bought this truck few months ago. I am going to start by replacing the temperature sensor and see if it does the trick but where is this sensor located on a 1990 4.0l Ranger?
Thanks a lot |
Tweet
#2 |
Year: 1983
Make: Ford
Model: Ranger
Engine: 5.0L EFI
Class: 4X4
Used For: Broke a lot of stuff, mostly own parts :-S
Rep Power: 12 ![]() iTrader: (0)
I don't know exactly where he is but look near themostat housing. The sensor probably just have 1 wire on it. To test the circuit, just unplug the wire to the sensor and plug it to th groun(your indicator must move to the hotter position, remove the ground from the wire and the indicator must return to the cold area).
__________________
Now i have 4 more cylinder to spin my wheels
Tweet
#3 | |
Junior Member
Year: 1990
Make: Ford
Engine: 4l
Class: 2wd
Quote:
Tweet
#4 |
Junior Member
Year: 1990
Make: Ford
Engine: 4l
Class: 2wd
I found it. It is not located at the thermostat but close to the intake manifold that is why I could not find it. I tested it like you suggested and sure enough the gauge went to max hot. Thanks again
Tweet
#5 |
Year: 1983
Make: Ford
Model: Ranger
Engine: 5.0L EFI
Class: 4X4
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
