Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-01-2008, 10:40 PM   #1
Lil Ranger
Lil Ranger's Avatar
Year: 1995 Ranger
Make: EXT Cab Splash
Model: 6" Lift 3" Body n 38" TSL's
Engine: Crap.. Not Enought.. 3.0 (WANT A 3.3 Stroker M90 Blower)
Class: Daily Driver--- Playing--- Off Road Recorvery!!!--- Car Shows
Used For: Intimidating (Crushing) Imports....
Lil Ranger is on a distinguished road
Default 4x4 C-5 to a 4x4 (5.0) C-4 Swap
I want to know what it would take to swap from a C-5 to a C-4??
Ranger is a V8 with a 4x4 C-5, I want to know how much Time n $$
it will be to swap to a 4x4 (V8) C-4, This way I can Keep The RPMs
n the Exhaust Sound down.. This will be my Daily Driver/Tow Rig...
What Will I Need??? Its is a Ext Cab Ranger...
Would a Short Bed, Reg Cab 4x4 V8 DriveShafts work???
I would like use as much stuff off the Parts F150 as I can..
Besides Trans n T. Case
DriveShafts??
Cross-Member??
Thanx,
Rob
Lil Ranger is offline   Reply With Quote
Old 04-03-2008, 08:55 PM   #2
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
You'll be reworking everything from the engine back. The AOD is longer and won't accept the RBV t-case without the custom adapters. There are a few options, leave it alone as is; put the AOD in with the adapter to the stock t-case, you might be able to use the driveshafts again maybe not, AOD and fullsize case and new driveshafts. You'll probably have to move the crossmember.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 04-04-2008, 02:48 PM   #3
Lil Ranger
Lil Ranger's Avatar
Year: 1995 Ranger
Default
What about a C-5 to a C-4 or C-6 Trans an T.Case
I mainly want a Full Size Truck Trans n Transfer Case
there, So I dont have to worry about "Over-Powerin"
the Lil C-5 Trans.. I want to b able to pull my Mustang
on my Car Trailer n not have to worry about it...
Thanx,
Rob
Old 04-04-2008, 07:30 PM   #4
projectnitemare
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Default
The C5 is the same as a C4. The transmission in your truck was a C5 converted to a C4 with the RBV tailshaft housing. For a C6 it will be the same as changing to any other trans, reworking everything. If you want overdrive you'll be probably going to an AOD. If not the C4 will be fine. I would suggest a good shift kit and a good secondary cooler and filter. Not because of the transmission but due to the towing, we do that with pretty much all vehicles that tow a lot.
Matt
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
