- Aug 7, 2007
- Jacksonville, FL
- Automatic
I've been tossing the ideas around how to lower transmission temps specifically while towing. Naturally transmission fluid needs to be in a proper temperature zone to get the best results. I'm curious what would be a better setup for both DDing and towing. Run a second large capacity cooler or to swap the stock cooler for a large one, and install an E-fan on the cooler. Of course with a switchable fan you'd be able to control temps from both too hot and too cold, but would it be worth it when not towing?
