Axle Swap
Project84
10+ Year Member
Amarillo Texas
Ok so if I want to swap out the front and rear end for full width axles then how can I swap out the front if it has an IFS? For the rear I was just going to grab the rear from a junk yard out of something with at least 4.10 gearing. But I have no clue how the whole front end would swap out with the IFS.
At the top of this page (or any other page on the site) is a big button that says Info - Technical. Its the third one, after Home, and Forums.
That is the tech library. It has tonnes of info, certainly enough to get you started.
It just bolts in... After some fabrication work, of course...
Look through the tech library, decide what axles, then find a few build threads to read on.
There is lots to read on here about it.
We can help you, but you need to research the process.
Oh and one more thing... Your wallet is gunna be pissed!
