d44 axles
diablo
15+ Year Member
I have recently gotten a d44 however I still need everything from the steering knuckles out.. Does anyone know if I can bolt up a set of knuckles off of an f-150 ttb.
The knuckles on a ttb d44, from everything I've been told, have a different vertical ball joint spacing then those on a solid d44. However, everything from the knuckle out, spindle/rotor/calipers etc is interchangeable.
-andrew
if u want the most heavy duty setup u can get ur hands on put some chebbie outers on it, knuckle and all, ull have yourself a 8 lug ranger :)
The spindles are NOT the same. The hubs, bearings and calipers are the same. The spindles will not work.
