- Feb 24, 2011
- Huntsville, AL
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
Since completing my 5.0L swap in my 2000 Ranger 4x4 in January, I have finally gotten it tuned right to run with my m5r2 manual tranny. It runs great except for one frustrating and potentially unsafe problem... it shuts itself off randomly. This is going to be a long post so I can adequately describe the problem and list all the crazy things I have done in the hopes of stopping it. Here goes...
The problem:
Usually, though not always, my truck will stall once it has warmed up. Generally it will lose power briefly, almost like it is losing fuel pressure or misfiring, and then it will pick back up in a split second and run fine. But then, at random and completely independent of engine load it will just die out of the blue. No sputtering or anything, just dead. When it does die, if I try to start it it will just crank. The fuel pump continues to run after it dies until I turn the key off.
However, if I turn the key off and then back on it will fire right up instantly and run for who knows how long until it dies again randomly. Occasionally it will spit some black smoke, like it is dumping too much fuel into the cylinders at random times. It is not burning oil. So I don't know if it is flooding itself out or what. Also, it does seem like it cranks a little longer than it should upon start up.
At one point it threw a p1356 code and a p1451 code. Canister vent solenoid malfunction and PIP signals present with engine not running. These codes were cleared and they have not shown up since, even though the problem persists.
What I have done:
Replaced fuel pump.
Replaced fuel filter.
Replaced camshaft position sensor.
Replaced crank position sensor.
Replace one coil pack that had a bad connector.
Checked all associated circuits.
Inertia switch is good.
Fuel pump relay is functioning as it should.
All of the grounds appear to be undamaged.
MAF sensor is clean.
Throttle body is clean.
No vacuum leaks.
I checked the pressure regulator on the fuel rail by removing the vacuum line to see if any fuel was present. There was not. Also, the fuel pressure remains high for at least 30 minutes after shutdown, so I assume the pressure regulator is working as it should.
I even hooked a volt meter to the fuel pump power wire and waited for the engine to run long enough to stall. Even when it sputters or dies completely the fuel pump is getting consistent power to it. At the fuel rail it holds steady at 57psi. The pressure does drop when the stumbling or dieing occurs, but the pressure jumps right back up immediately even after it dies.
None of the above attempts have solved the problem. I don't know what else to check, and I am very tired of throwing money at it at this point. I don't see why the tune that is on it would cause it to die at random, and I find it difficult to believe that the computer is all of a sudden malfunctioning. This problem has only been present for the last 3 weeks or so. I am extremely frustrated at this point after trying everything above.
Any help or advice would be greatly appreciated. It is my daily driver and I really don't want to lose my power steering at an intersection.
The problem:
What I have done:
Replaced fuel pump.
No vacuum leaks.
